base map for blitz exhaust
Posted: Tue Apr 05, 2022 9:22 pm
by calebuy
hi guys im new to hondata. i have a 2018 civic fk8. what base map should i be using for blitz exhaust nurspec. i dont see my exhaust in the drop down list for "exhaust" and "front pipe". the blitz exhaust has the front pipe included in case you are wondering. below is the spec sheet of my exhaust:
SPECIFICATIONS:
Version: Nur-Spec VSR
Material:
- Muffler: Stainless Steel (SUS304)
- Tips: Stainless Steel (SUS304) Stainless Titanium Color VSR
Size Diameter (mm):
Main Pipe Size: 70 to 60 X 2, 50 X 1
Tip O.D.: 114.3 X 2, 101.6 X 1
Tail Design: 2.5R Curl
Piece Construction: 3
Re: base map for blitz exhaust
Posted: Fri Apr 08, 2022 6:52 pm
by Lorre
Hey man, personally If I’m going for an OTS map, and the catback is the only mod you have I would select the “standard” 91 or 93 octane map regardless of improved throttle response or not.
The exhaust map is more suited for…if an aftermarket exhaust was changed. The front pipe is post cat, so I would just go with a standard 91 or 93 map.
Posted: Fri Apr 08, 2022 7:24 pm
by calebuy
Lorre wrote: Fri Apr 08, 2022 6:52 pm
here the list of mods i have:
- hks down pipe
- gruppem intake
- blitz nurspec exhaust
- hks BOV (recirced)
Posted: Fri Apr 08, 2022 11:41 pm
by Lorre
In that case, I would pick a map that’s closest to what you have.
I think there should be one for exhaust and intake?
Posted: Fri Apr 08, 2022 11:51 pm
by calebuy
Lorre wrote: Fri Apr 08, 2022 11:41 pm
yes there is for the exhaust and intake. the rest i should just put "stock"?
Posted: Sat Apr 09, 2022 7:08 am
by Lorre
calebuy wrote: Fri Apr 08, 2022 11:51 pm
[quote=Lorre post_id=124868 time=<a href="tel:1649486519">1649486519</a> user_id=36618]
[/quote]
Frankly I don’t have Hondata yet, so I can’t see what is exactly available but I’ve done a fair bit of reading up on what maps are available so roughly have an idea on the maps available.
I’m looking to get an OTS map with a catback, so yes, I would put the rest as stock as a catback system don’t usually require a tune to run properly.
Perhaps some of the more experienced guys can chime in.
Hope this helps!
Posted: Sun Apr 10, 2022 4:51 am
by calebuy
Lorre wrote: Sat Apr 09, 2022 7:08 am
Hope this helps!
[/quote]
thank yopu so much. ur advice is actually a big help.
