need help with tune
need help with tune
got a 07 fa5 that has
dc sports intake
catback exhaust
rdx injectors forgot the cc's
350cc fuel pump i believe
have a base map i made but feel like theres a hesitation when changing gears
dc sports intake
catback exhaust
Re: need help with tune
Are the RDXs OEM or aftermarket?
i mean rc injectors 440cc got the ccs
Did you get an injector latency sheet in the box? It would show injector data by battery voltage?
Or can you send a link to the exact ones you purchased?
The injector data is important to getting it tuned properly is why we need that information.
Okay I found the data on their site. Can you post a datalog that you have showing how it drives right now?
these are the datalog i got for a couple driving
Which calibration are you driving on? Can you post it so I can look at it?
should be this one
Is this a calibration you've been tweaking, or did you find it somewhere?
You have the K20Z3 in there correct, your title on the original file said K24? You don't have a K24 in the car do you? Or maybe this file you found was setup for a K24...
Yeah either way this file is nowhere near complete or setup properly for your setup. We would want to go in and tune it completely by going in and tuning each cam angle. Let me know if that's something you want to do or not, you'd be looking at 10-12 revisions at least. Unfortunately there isn't really anything we can use from this old file, so we'd have to start you on a basemap using my stuff and go from there.
Let me know if that is something you want to do. Also, you have the rev limiter at 7800 in this calibration is that something you want to keep? If you have the K20Z3 in there, they can rev to 8600. Let me know on that so I can set it up however you want it.
yea id do that yea it was for a k24 but took it out and used the same file just tuned a bit but i know its not prperly tuned
Okay sounds good. You didn't get any paperwork with the injectors by chance? The injector data on RC's website is very different from the base RC calibration from Hondata. If you still have the packaging, there might be some paperwork inside that shows something like this https://www.rcfuelinjection.com/Portals ... y_Time.pdf . Either way we would need to make some adjustments to them, it's just that the data is so different I'm not sure which way to start is all. If you don't have any paperwork in the original packaging showing something like the link I provided I'll start on the rich side and trim them down.
But let me know. Then I can get the first calibration to you.
i checked and no i dont have it
i looked all over and nothing probably somebody threw it away
