Page 1 of 2
Code P0234 (Overboost Error)
Posted: Sun Apr 03, 2022 12:45 pm
by Jaye
I just recently got my Flashpro for my 2019 civic si. Car is stock.
Flashed it with the +6 tune.
Every time Id do a pull the car goes into limp mode and the check engine light, VSA, EPS, brake hold, and some others would come on.
Im running the Hondata Mobile on my nav, and the code P0234 (overboosting problem) would show on it.
Ive tried reflashing the car multiple times already and that would fix the lights but I just run back to the same problem over again.
Anyone else having this issue or can help?
Re: Code P0234 (Overboost Error)
Posted: Mon Apr 04, 2022 9:35 am
Post your calibration and a datalog using that calibration that shows when this occurs.
Posted: Sun Apr 17, 2022 8:38 pm
by Jaye
Spunkster wrote: Mon Apr 04, 2022 9:35 am Post your calibration and a datalog using that calibration that shows when this occurs.
Sorry for the late reply.
Below is the calibration and datalog.
Posted: Mon Apr 18, 2022 10:00 am
Why do you have the secondary O2 sensor disabled?
Posted: Mon Apr 18, 2022 12:31 pm
by Jaye
Oh I must have accidentally disabled it while I was going through the calibration section.
Anything I can do to prevent this error from occurring?
Posted: Mon Apr 18, 2022 3:46 pm
Do you have any throttle pedal modifiers installed?
Posted: Mon Apr 18, 2022 6:56 pm
by Jaye
No I don’t have anything installed except for the FP
Posted: Tue Apr 19, 2022 9:30 am
If you return to stock, form the online menu, do you still get the error?
Posted: Tue Jun 21, 2022 3:38 pm
by Jaye
Spunkster wrote: Tue Apr 19, 2022 9:30 am If you return to stock, form the online menu, do you still get the error?
Hey, I know it’s been a while but I still have this problem. And no, I returned it to stock and don’t get the error anymore. It just keeps happening every time I flash it back tho.
Posted: Tue Jun 21, 2022 4:00 pm
Post the calibration used and a current datalog showing the issue made with that calibration.
Posted: Thu Mar 09, 2023 4:40 pm
by Andrey_mrz
I have the same issue happening. We’re you able to fix it?
Posted: Thu Mar 09, 2023 5:18 pm
Spunkster wrote: Tue Jun 21, 2022 4:00 pm Post the calibration used and a current datalog showing the issue made with that calibration.
Posted: Sat Mar 18, 2023 4:40 pm
by Jaye
Jaye wrote: Sun Apr 17, 2022 8:38 pm
Posted: Mon Mar 20, 2023 4:09 pm
That is from almost a year ago was not using the current software.
Posted: Tue Mar 21, 2023 8:11 pm
by Jaye
Here's a datalog I just did.
