Page 1 of 3
2011 si help with K&N sri tune
Posted: Fri Mar 25, 2022 8:46 pm
by Krustydogs
I just got the K&N sri intake. I have the flash pro. I loaded the K&N base map calibration and now i feel like my car is running a little weird now.
Re: 2011 si help with K&N sri tune
Posted: Fri Mar 25, 2022 9:40 pm
by Krustydogs
Krustydogs wrote: Fri Mar 25, 2022 8:46 pm I just got the K&N sri intake. I have the flash pro. I loaded the K&N base map calibration and now i feel like my car is running a little weird now.
The only mods i have is K&N Sri V2 and im using 93 octane
Posted: Fri Mar 25, 2022 9:56 pm
by EFICU
Can you post a datalog of 10-20 minutes of driving to see how it's acting?
Posted: Fri Mar 25, 2022 10:56 pm
by Krustydogs
I don't know if this is long enough datalog but I can upload another tomorrow.
Posted: Fri Mar 25, 2022 11:54 pm
by EFICU
Overall it's not too bad really. We can definitely make it better though.
Do you have any planned mods in the near future, or is the K&N SRI the only mod into the foreseeable future?
Posted: Sat Mar 26, 2022 12:10 am
by Krustydogs
In the future i want to get Skunk2 Racing Alpha Series Race Header, and Skunk2 Megapower rr exhaust. Right now just the k&n sri
Posted: Sat Mar 26, 2022 12:30 am
by EFICU
Okay, since you plan to add some mods in the near(ish) future, we can do a quicker tune on it now and then if you still want my help once you add the header and exhaust we can go in and do a thorough complete tune where we tune all cam angles. We can do that now if you wanted to, although it's time consuming on your part making twenty minute datalogs. But doing it this way, it should get make it fun to drive and super safe for now. It will still take a couple revisions to dial it this way, but the long route takes 10-12.
Either way, for now, give this one a drive and see what you think. I have it set up to be a hybrid calibration, but some K&N cars like to be speed density tuned. But try this one out, see what you think, and make a twenty minute datalog with at least one wide open throttle (WOT) pull in third gear from 2500-8600 so we can see the WOT fueling too.
Krusydogs.Hybrid.Rev01 (Blended)(Vtec4600).fpcal
Posted: Sat Mar 26, 2022 8:06 am
by Krustydogs
I don't mind going the long route, and I'm really grateful for you helping me out. Here's my datalog from this mornings drive with the revision you gave me.
Posted: Sat Mar 26, 2022 9:09 am
by EFICU
Sounds good, we can go in and tune it properly. I'll have you make one for datalog on this next calibration to verify the primary o2 sensor is working right before we move forward. Take this one for a similar datalog and drive, just be sure to get a clean third gear WOT pull. I want to verify the o2 sensor is working properly before moving forward. The fuel in WOT was a little bit leaner than I would have imagined for the first file, so if it's still lean in this one the o2 sensor isn't working properly. But we'll see, take it for a spin when you can.
Krusydogs.Hybrid.Rev02 (Blended)(Vtec4600).fpcal
Posted: Sat Mar 26, 2022 10:17 am
by Krustydogs
Here's the datalog
Posted: Sat Mar 26, 2022 11:15 am
by EFICU
Okay it looks like the sensor is working just fine, so that's good. So we can go in and tune it. We will start on the 0* cam angle with vtec at 4500. The 0* cam angle is the least powerful, so don't get discouraged when it doesn't feel as strong. It basically lays the foundation for everything we do moving forward. So take this one for a spin when you can, keep datalogging like you have been for the twenty minutes and a third gear WOT pull. Your driving style in the datalogs is great.
Krustydogs.SD.Rev01 (0Cam)(Vtec4500).fpcal
Posted: Sat Mar 26, 2022 1:48 pm
by Krustydogs
Vtec cracked a little bit louder probably because the 0* cam angle
Posted: Sat Mar 26, 2022 4:45 pm
by EFICU
Yeah the 0* cam angle sounds wilder than it feels for sure, so that is probably what you heard. Here is the next one, we will now move to the 15* cam angle with vtec at 4500 again. Take this one for the same type of drive and datalog like the last one.
Krustydogs.SD.Rev02 (15Cam)(Vtec4500).fpcal
Posted: Sat Mar 26, 2022 6:46 pm
by Krustydogs
Here's the new datalog
Posted: Sat Mar 26, 2022 7:09 pm
by EFICU
Looks really good. I made some adjustments for the next one, we will now move to the 30* cam angle with vtec at 4500. Take this one for the same type of datalog and driving style.
Krustydogs.SD.Rev03 (30Cam)(Vtec4500).fpcal
