B18C1 - Looking for a clean Basetune/Possible Etune
Thatb0iray88
Post by Thatb0iray88 »
Hey guys,
If possible as the title states I am looking for a clean basetune/possible E-tune.
My setup:
B16B Head
B18c1 w/Nippon Racing GSR 81MM P72 Pistons & Scat H-Beam Rods
550CC Deatschwerks Injectors
Hondata S300v2
Edelbrock Intake manifold
Ram Horn Turbo Manifold
Ebay GT3076R .63 AR
3" DP w/ no exhaust currently
I attached my current basetune. Any help regarding this would be greatly appreciated
CalibratEd
Re: B18C1 - Looking for a clean Basetune/Possible Etune
Post by CalibratEd »
Thatb0iray88 wrote: Thu Mar 24, 2022 1:41 am Hey guys,
My setup:
B16B Head
Hondata S300v2
Ebay GT3076R .63 AR
I can help with an E tune. Can you provide datalogs with wideband data?
-Ed
Instagram: calibrated.tuning
Thatb0iray88
yes, how do you want me to datalog? which rpm & gear?
Thatb0iray88
Heya,
I managed to record 2 driving sessions this morning about 5 - 10 minutes apart.
The second recording is longer than the 1st.
1st issue I definitely have is, when just pulling out of my parking spot the car is bouncing off and on in a jerking motion. but once I get started driving it acts normal.
Thank you
CalibratEd
Thatb0iray88 wrote: Mon Apr 18, 2022 4:36 am Heya,
Thank you
Sounds good. I will look over the logs and get back to you.
-Ed
CalibratEd
Double check your wideband connection. I do not see it populating data in the datalog. Is the wideband functioning and fluctuating while at idle and normal driving?
-Ed
Thatb0iray88
Yes it's functioning and fluctuating properly, I'm not sure why I am just now seeing your reply. Some reason I didn't get a notification
CalibratEd
Thatb0iray88 wrote: Thu Apr 28, 2022 2:47 pm Yes it's functioning and fluctuating properly, I'm not sure why I am just now seeing your reply. Some reason I didn't get a notification
What pin is it using on the ecu to connect it to the Hondata?
-Ed
Thatb0iray88
I'm not sure what the # pin it is but I have pics that may help.
The white/red one is the one that goes to the afr gauge
CalibratEd
Look up the pin out and see if it is connected to a pin required by Hondata.
-Ed
D14 should not be used for a wideband input as it cannot see the full voltage range. Use one of the other inputs instead such as ELD.
Thatb0iray88
Thanks fellas, I will be checking this out today. very likely I have the signal wire on the afr gauge not wire correctly.
Thatb0iray88
I rewired the aem afr to D10 ELD & also changed the hondata to read from D10 as well.
I attached 3 different datalogs, Hopefully these look okay. sorry for the late reply, I was dealing with a crank no start situation most of the day just to discover that the plugs had oil on them so I had to change them out and it started up like new... long day...
CalibratEd
Thatb0iray88 wrote: Sat Apr 30, 2022 3:46 pm I rewired the aem afr to D10 ELD & also changed the hondata to read from D10 as well.
I am now able to see the wideband data in the datalog.
It seems to be running Rich at idle and need some fuel before boost. Did you decided if you needed something to get you to a tuner or did you need a full ETune?
-Ed
Thatb0iray88
I managed to haul the Integra to a tuner shop about 20 minutes from me. I found out that my rebuilt distributor isn't any good and would cause my car to die when going into vtec.
I managed to grab a 99 si distributor for $93 bucks off of Facebook marketplace a few days ago, so I'm just waiting on the odb2 to odb1 distributor adapter tomorrow and tuning will continue some time next week.
I only have 550cc injectors atm and will be upgrading within the next two weeks to 750 or 1000cc so I'm interested in doing etuning once they arrive. I'll keep you posted.
