Need a base map for my 08 SI
GoldeunAgma
Post by GoldeunAgma »
I have a 08 SI that I'm installing a Hybrid Racing cold air intake on tomorrow, and would like a base map for it before I go ahead with the install. Rather be ready to have it running smoothly right away.
Thank You if anyone takes the time to help!
Agma_SI
EFICU
Re: Need a base map for my 08 SI
Post by EFICU »
Do you have any other performance mods besides the HR intake?
EFICU
Post by EFICU »
Just in case we don't cross paths before you install it, here is a basemap to start and drive it. Once you get it up and running, take this calibration for a twenty minute drive and datalog that drive. On the drive, make one wide open throttle (WOT) pull from 2500-8600 rpms in third gear so we can see the WOT fuel.
GoldeunAgma.SD.Rev01 (Blended)(Vtec4600).fpcal
GoldeunAgma
I have nothing else engine wise done too the car, Thank you for the response- ill run the calibration and datalog that drive, ill be back here Thursday or Friday with results. This is just temporarily though, as on Friday ill have a 2.5" catback Full Race exhaust- which I would greatly appreciate help with that also until I can get it dyne tuned here in Western WA.
EFICU
Post by EFICU »
Sounds good. The exhaust won't make much of a difference in the tune since you still have the stock cat in there. But we can clean it up for the exhaust if it does make some changes.
