Econ button boost (Hondata mode)enabled
xiplus
Post by xiplus »
My car is a Civic 1.5T, write +6psi, turn on ECON mode, press the throttle pedal in place and the throttle does not respond.
Turning off the ECON mode works properly
Re: Econ button boost (Hondata mode)enabled
What exact model is your vehicle? Can you tell us the ECU part number or the calibration ID?
xiplus
Post by xiplus »
ECU ID 37820-5AF-B420M1
xiplus
Post by xiplus »
Hondata wrote: Sun Mar 13, 2022 8:37 am What exact model is your vehicle? Can you tell us the ECU part number or the calibration ID?
2020 china civic hacthback MT
ecu 37820 5AF B420M1
xiplus
Post by xiplus »
help thanks
We believe the problem has been fixed. Please update FlashProManager and upload to your vehicle again.
xiplus
Post by xiplus »
Hondata wrote: Fri Mar 25, 2022 9:17 am We believe the problem has been fixed. Please update FlashProManager and upload to your vehicle again.
Thank you and I'll try to rewrite it when I have time
