Page 1 of 4
2014 civic si looking for help and just a quick rundown of the combination.
Posted: Fri Mar 04, 2022 1:24 pm
by Og7x
My mods
DC Sport SRI
BuddyClub exhaust ... 2.75 in
Ktuned catback 2.75 in
Re: 2014 civic si looking for help and just a quick rundown of the combination.
Posted: Fri Mar 04, 2022 1:30 pm
by EFICU
Okay here is the first calibration. Shoot for twenty minutes and one third gear WOT pull from 2500-7500.
Og7x.SD.Rev01.1 (0Cam)(Vtec4500).fpcal
Posted: Fri Mar 04, 2022 2:45 pm
by Og7x
Car feels better then the base (SRI CAT DELETE CATBACK) Map. idle feels fine as well.
Posted: Fri Mar 04, 2022 3:03 pm
by EFICU
Looks good for a start, little rich but no big deal for a start. I made some adjustments, we will now move to the 15* cam angle with vtec at 4500 again. This one should feel stronger with the cam angle at 15*. So it should get better as we go. Same datalog and driving style with the third gear WOT pull.
Og7x.SD.Rev02 (15Cam)(Vtec4500).fpcal
Posted: Fri Mar 04, 2022 4:14 pm
by Og7x
Yup, it does feel stronger. was able to get a 3rd gear pull right before the traffic started on the highway.
the datalog is bigger then what can be attached to this, is there another way i can send it to you? Or do I have to try to datalog it again but make it shorter?
thanks again for the help.
Posted: Fri Mar 04, 2022 4:47 pm
by EFICU
You can shorten the datalog in FlashPro manager. With the timeline open, right click around the 20 minute mark and click “set new end”. Then save it.
Or, my email address is in the “calibrations” tab in you files I send you.
Posted: Fri Mar 04, 2022 4:50 pm
by Og7x
okay heres datalog #2
Posted: Fri Mar 04, 2022 4:59 pm
by EFICU
Looks like you saved it as a calibration, or saved the calibration. Double check the name and file so it's a .fpdl file.
Posted: Fri Mar 04, 2022 5:11 pm
by Og7x
oh sorry about that.
Posted: Fri Mar 04, 2022 5:34 pm
by EFICU
No problem at all. It's looking great. For the sake of shortening things up for data gather, we will do one on the 30* cam angle now with vtec at 4500. Take this one for a drive when you can, same datalog and driving style.
The injector duty cycle is getting up there. We'll see where we land towards the end. But injectors might be a wise upgrade soon, but I'll keep an eye on it when we blend everything out. But take this one for a spin and we'll see how it all looks.
Og7x.SD.Rev03 (30Cam)(Vtec4500).fpcal
Posted: Fri Mar 04, 2022 9:56 pm
by Og7x
okay this is datalog number 3
Posted: Fri Mar 04, 2022 10:14 pm
by EFICU
This one will be the last one with the cam angle locked, then we blend it out. For this one, we only need a ten minute datalog, just be sure to get a clean third gear WOT pull. This will be the 40* cam angle with vtec at 4500.
Og7x.SD.Rev04 (40Cam)(Vtec4500).fpcal
Posted: Fri Mar 04, 2022 10:26 pm
by Og7x
okay i will do this after work. im done work at 8am eastern time. thank you so much.
Posted: Fri Mar 04, 2022 10:35 pm
by EFICU
Okay sounds good. We'll see how it looks.
Posted: Sat Mar 05, 2022 6:33 am
by Og7x
hey. how does this look.
