FlashProManager 3.9.0
V3.9.0 (3 Mar 2022)
  • [FK2] Added rev limiter modifications, high pressure pump tables.
  • [2006-2011 Si] Fixed active tuning maximum load not going above 100 kPa
  • [Multiple vehicles] Fixed full throttle shift rpm changing to 0 rpm.
  • Add setting flag to enable 4k monitor support.
Download here
Additionally the FK2/FK8 high pressure fuel pump modifications have been split into two parts - the changes need for the different fuel pump hardware (which is fixed) and the PID / feed forward control tables (which the user can change). Normally you would select both the modification files.
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Bain
Re: FlashProManager 3.9.0
Post by Bain »
Hi,
Is the below only for the hondata fuel pump, or does the XDI pump now also work on the FK2?
"high pressure pump tables"
Let me ask XDI.
Bain
Post by Bain »
Hondata wrote: Sun Mar 06, 2022 10:46 amLet me ask XDI.
Thank you so much for the assistance, as the XDI pump works on the FK8 I thought the change had to come from Hondata for it to work, not XDI.
Or is it a half half thing? Again thanks for everything you okes do to assist us.
Yes, it has to be a joint effort to make tuning changes. XDI is good to work with.
Do you have the XDI pump in the vehicle now? If so I can provide some modifications files to get it running.
lightarmy10
Post by lightarmy10 »
Hondata wrote: Mon Mar 07, 2022 9:13 am Yes, it has to be a joint effort to make tuning changes. XDI is good to work with.
Hi , I want to ask that now i have Hondata flashpro for 2018 10th Gen Civic Hatchback CVT , i'm planning to sell my car and buy 11th Gen Civic CVT . just curious, can my hondata flashpro still be installed on gen 11?
Bain
Post by Bain »
Hi, I have heard good things about the XDI pump, some of my friends wth FK8's say it really works great.
I have not bought one as I was not sure when and if it will work on the FK2, by your comment I take that it will now also work on the FK2?
Bain
Post by Bain »
I will be looking at getting one then, please can you suppky em with the files.
lightarmy10 wrote: Mon Mar 07, 2022 6:35 pm Hi , I want to ask that now i have Hondata flashpro for 2018 10th Gen Civic Hatchback CVT , i'm planning to sell my car and buy 11th Gen Civic CVT . just curious, can my hondata flashpro still be installed on gen 11?
Yes.
Bain wrote: Tue Mar 08, 2022 4:02 am I have not bought one as I was not sure when and if it will work on the FK2, by your comment I take that it will now also work on the FK2?
That is a question for XDI.
lightarmy10
Hondata wrote: Tue Mar 08, 2022 8:23 am
Yes.
No need to jailbreak the ECU , just do the same step by step reflashing like the 10 th Gen if i reflash choose the basemap file to 11th Gen right?
Yes, unlock from the old car, lock to the new one, upload a calibration.
