Any help with a base map for ls vtec turbo?
Posted: Tue Mar 01, 2022 4:29 pm
Needing a lsv turbo base map just to break in the motor before I take it to the tuner to dyno(given he’s almost 4 hours away)
Here’s my set up
Gsr head freshly machined stock cams and valve train
Bbk ssi 5007 intake manifold with skunk 2 74mm tb
FIC 2150cc injectors
Aem regulator (-8 feed, -6 return) on e85
Walboro 525 pump
B18a1 block
9.8:1 cp pistons and Manley rods
Fresh stock crank
1320 top mount with borgwarner sx200 turbo
3” intercooler with piping
44mm tial wastegate and vsr bov
4 bar map sensor
Stock ls trans non lsd
Acp clutch unknown flywheel
P72(vtec converted) with hondata s300
Thanks guys
Here’s my set up
Walboro 525 pump
B18a1 block
Fresh stock crank
4 bar map sensor
Thanks guys
