S300 v3 CAN output
Posted: Fri Feb 18, 2022 1:44 pm
In CAN output documentation there are values for knock/detonation in the Hondata CAN protocol, though it’s noted this is only available on kpro.
I’m using an s300 v3 in a p72-a01 with knock board so in this case values should be in the ecu. Will the s300 send these in this case or does the s300 simply not output?
