Maf sensor to IAT sensor on a boostquestion
tsxmiichael
Post by tsxmiichael »
Hi guys how are you today! I have question! I have a automatic transmission tsx cu2 and im try to see if its possible to eliminate the maf sensor and remplace it with IAT sensor! Or i have to used a adapter and leave it connected the maf sensor and install the iat in the pipes
Re: Maf sensor to IAT sensor on a boostquestion
The MAF must remain connected and in the air stream even if tuning via speed density.
tsxmiichael
Where should I locate the maf sensor! In front of the turbo inlet or in the piping?
I would recommend similar to an OEM setup.
tsxmiichael
I locate the mad sensor here where i mark in the picture! I was thinking to locate the maf sensor in front of the turbo with a filter and pipe and the IAT close to the tbody! Will thag be correct or should i leave the maf sensor where i locate? My worries is that it will get psi
tsxmiichael
Something like this but i will have to get a 4” tube cause i have a 6262! And im not sure if the filter will make me loose some power there! And also put the IAT sensor close to the tbody And thanks for responding
tsxmiichael
Spunkster wrote: Tue Feb 15, 2022 5:15 pm The MAF must remain connected and in the air stream even if tuning via speed density.
Question i will leave my datalog to see if my AFR is bad cause from nowhere is starting to boost cut now and sometimes it try to turn off, and when i turn the primary oxygen sensor off it get into boost but it not tuning ok! There is not boost leak or anything! The car was fine and one day i just turn it on and every time i go into high boost is boost cutting but its not going to the boost its set
It looks lean. You may need to discuss this with your tuner.
tsxmiichael
Thanks! I using e85 and not sure if the e85 im using is bad! My sensor reading 77% i have it in a gasoline container for like 2 weeks i mix it a bit with gas and drive a bit better but I definitely will and also 🤔 i will have to check my injectors just to make sure! I out a old tune and it get into boost but it hold me back and i keep my eyes on the afr but i will see what my tuner say, i text him but he haven’t responded yet
tsxmiichael
Spunkster wrote: Mon Oct 10, 2022 9:29 am It looks lean. You may need to discuss this with your tuner.
Was the fuel pump line that was blow! Find out yesterday! Thanks for the info too🙏🏽🙏🏽🙏🏽
