Need some help getting my car going. I need a base map just to get the car running for tuning. If anyone reading this could lend a hand. I would really appreciate it! I have a:
K24a2
Stock Head
Precision 60/62
RDX 440 Injectors
50mm TurboSmart Waste
76mm Throttle Body
Skunk 2 Ultra Street Manifold
3" Exhaust
KPRO V4 Hondata
255 Walbro Fuel Pump
Stock Map Sensor
AEM Wide Band
Type-S Tranny 4.3 final drive (wasn't sure if I needed to add this in there but doesn't hurt)
Thank you in advance!
06 K24A2 Turbo Base Map, Please?
- CalibratEd
- Contact:
Re: 06 K24A2 Turbo Base Map, Please?
I can lend a hand. Are you able to read the wideband in the Hondata software? When do you plan on getting the car tuned?
-Ed
-Ed
Instagram: calibrated.tuning
Im going to hook up the hondata tonight and try to get a wide band reading. I was waiting on my exhaust to get welded and I added the bunge for the O2. I’ll have a reading tonight and I’ll send over a log. I can’t drive just yet. Weather is shit right now. Sadly. I’m waiting on my tuner to have some time. Realistically I’m looking at about a month or so. My tuner is backed up with a lot of work and in the process of moving shops. I’ll update the post once I get the reading. I’m mounting my down pipe as we speak. FYI car starts it’s on an all motor closed loop tune. I’m just not sure the car will run properly to get there.
- CalibratEd
- Contact:
If the car idles and drives on an NA tune that is a good start. Now it’s a matter of dialing in fuel a bit and keeping it out of boost to make it to the tuner.B0000ST wrote: Sat Feb 12, 2022 5:03 pm Im going to hook up the hondata tonight and try to get a wide band reading. I was waiting on my exhaust to get welded and I added the bunge for the O2. I’ll have a reading tonight and I’ll send over a log. I can’t drive just yet. Weather is shit right now. Sadly. I’m waiting on my tuner to have some time. Realistically I’m looking at about a month or so. My tuner is backed up with a lot of work and in the process of moving shops. I’ll update the post once I get the reading. I’m mounting my down pipe as we speak. FYI car starts it’s on an all motor closed loop tune. I’m just not sure the car will run properly to get there.
-Ed
update:
so, car runs. wideband was reading 14.7 once the motor was warming up. once the temp gauge reached 3 qtrs. the engine rpm fall and the wide band read 16.7. as if the engine was dying but comes back to life. i was trying to log but the hondata was telling me i needed to re upload the current map with the new version. with work and shit weather. its a little hard to make time for her. i also had to tend to some leaks from the BOV. im going to try to make some time this week so i could log and send something over for you to see. for now im quite happy that she runs. again, i appreciate the help!
- CalibratEd
- Contact:
Great to hear you got it started. I’m sure the car will idle better once the proper injector data is entered and the fuel is dialed in. Yes, post the tune file and a datalog when you can.B0000ST wrote: Tue Feb 15, 2022 6:50 pm update:
-Ed
