K20a-ITR map doesn't go into closed loop ever
Posted: Wed Feb 09, 2022 12:25 am
Hello all,
I have recently had a Kpro V4 installed in my car, and have been searching these forums for advice on how to get started with it all.
I have seen quite a few mentions of the above map K20a-ITR which is the only suitable basemap for my car and also have downloaded quite a few logs from users of this map.
However, my concern is that the entire logs are all in Open Loop. There is no closed loop anywhere in the map.
I understand that tuning should be done in Open Loop to get the fuel tables populated correctly, but my worry is that if the map fuel tables are wildly wrong for my car, wont it run like crap as the ECU wont be doing any corrections based on AFR.
Looking at the map parameters, I cannot understand why the logs appear to have no closed loop - the map seems to be setup that it should run in closed loop under 87 KPA and then enter open loop from 87+ KPA which is how I would want it.. but if you look at of the log files below from this map, you can see the car is always in fuel status 4 - Open Loop, the entire time
Can anyone assist or explain this to me?
