Need Help with CAM ANGLE. difference between CAMCMD and CAMANGLE
Posted: Thu Feb 03, 2022 7:44 am
by pmateo93
Hello,
I recently built my turbo car.
I have stock k20z3. I'm in the process of tuning via datalog with Derek Robinson from Innovative Motorworks.
The car is presenting a difference in the cam angle, a kind of oscillation.
We changed the VTC actuator, Vtc selenoid, VTC filter, VTEC filter, camshaft sensor.
See the attached image. The issue It is more noticeable when the car is cruising, at low speed better cam angle.
Re: Need Help with CAM ANGLE. difference between CAMCMD and CAMANGLE
Posted: Thu Feb 03, 2022 8:53 am
What vehicle is that? Are you using an 02-04 ECU or 05-06 ECU?
Edit: Sorry, ignore this - got confused with the KPro.
Posted: Thu Feb 03, 2022 9:05 am
by pmateo93
Hondata wrote: Thu Feb 03, 2022 8:53 am What vehicle is that? Are you using an 02-04 ECU or 05-06 ECU?
Honda Civic SI 2008 Canadian OEM ECU
Posted: Thu Feb 03, 2022 10:21 am
What oil are you using?
Posted: Thu Feb 03, 2022 12:26 pm
by pmateo93
Spunkster wrote: Thu Feb 03, 2022 10:21 am What oil are you using?
Repsol 10w-40
Posted: Thu Feb 03, 2022 12:35 pm
Do you have a restrictor on the oil line for the turbo?
Posted: Thu Feb 03, 2022 1:34 pm
by pmateo93
Spunkster wrote: Thu Feb 03, 2022 12:35 pm Do you have a restrictor on the oil line for the turbo?
Yes, the turbo has a restrictor.
Posted: Thu Feb 03, 2022 1:52 pm
What oil pressure are you getting?
Posted: Thu Feb 03, 2022 2:00 pm
by pmateo93
Spunkster wrote: Thu Feb 03, 2022 1:52 pm What oil pressure are you getting?
At Idle: 20-21 PSI
Cruising: 60-80 PSI
WOT: 90 PSI
Posted: Fri Feb 04, 2022 9:17 am
by pmateo93
I have this ecu part 37820-rrb-k01 any problem with that ecu?
Posted: Fri Feb 04, 2022 10:20 am
That ECU is compatible.
Posted: Mon Feb 07, 2022 9:06 pm
by pmateo93
Spunkster wrote: Fri Feb 04, 2022 10:20 am That ECU is compatible.
UPDATE: We change the ecu and we still have the same issue with the cam angle.
Posted: Tue Feb 08, 2022 10:38 am
Then it sounds like a wiring or mechanical issue in this vehicle.
Posted: Sat Dec 16, 2023 8:26 am
by vsperformance
You solved it or still with this issue?
