Page 1 of 2
ANYONE CAN HELP ME SET UP A BASE MAP FOR K24/K20 TURBO
Posted: Wed Jan 19, 2022 7:05 pm
by emzzie012
LOOKING FOR A BASEMAP FOR K24A2BLOCK/K20A2HEAD TURBO (STOCK BLOCK AND SUPERTECH HEAD PACKAGE AND ARP HEADSTUDS)
ID1000CC INJECTORS,PRECISON 6266 TURBO, 4BAR MAP SENSOR, 44MM TIAL WASTEGATE 7PSI SPRING
JUST NEED HELP TO GET MY CAR STARTED TO TEST IT OUT TO MAKE SURE THERE'S NO LEAKS BEFORE I GET IT TUNED.
Re: ANYONE CAN HELP ME SET UP A BASE MAP FOR K24/K20 TURBO
by emzzie012
THANKS IN ADVANCE
Posted: Thu Jan 20, 2022 9:29 am
by CalibratEd
I can help out. Does the car have a working IACV?
-Ed
Posted: Fri Jan 21, 2022 6:04 pm
by emzzie012
yes it does have IACV
Posted: Fri Jan 21, 2022 8:34 pm
by CalibratEd
emzzie012 wrote: Fri Jan 21, 2022 6:04 pm
What ECU are you running and do you have a working wideband?
-Ed
Posted: Mon Jan 24, 2022 1:49 am
by emzzie012
Pnd hondata kpro v4 and i dont have a wideband yet
But i can use the hondata app on my phone
Posted: Fri Jan 28, 2022 9:11 pm
by CalibratEd
Give this a try. Let me know if it starts and if you can get it to idle. If the car is able to idle send me a datalog of it at idle after it has reached operating temperatures. If you can drive it around even better. The map should run rich. I can lean it out after a few revisions.
- Ed
Posted: Sat Jan 29, 2022 7:00 pm
by emzzie012
thank you so much for your help @CalibratEd i will update you once i get the car started and send you datalog
i apreciate your help man.
Posted: Mon Jan 31, 2022 9:47 am
by CalibratEd
emzzie012 wrote: Sat Jan 29, 2022 7:00 pm
No problem.
-Ed
Posted: Wed Feb 02, 2022 8:47 pm
by emzzie012
here's the datalog idling and rev
Posted: Wed Feb 02, 2022 10:57 pm
by emzzie012
idling and driving
Posted: Fri Feb 04, 2022 8:25 pm
by emzzie012
CalibratEd wrote: Fri Jan 28, 2022 9:11 pm
- Ed
here are the datalogs
thanks CalibratEd
Posted: Sun Feb 06, 2022 8:29 pm
by CalibratEd
emzzie012 wrote: Fri Feb 04, 2022 8:25 pm
- Ed
thanks CalibratEd
Seems to be running a lean. I added more fuel. Load the revised file and Create a similar datalog.
Posted: Tue Apr 05, 2022 1:27 pm
by Jerzeejay
CalibratEd wrote: Thu Jan 20, 2022 9:29 am
-Ed
Hey I’m in need of similar help with my k24/20 help and I’m in the sticks pm me or ig message jjerzee
Posted: Tue Apr 05, 2022 1:51 pm
by CalibratEd
Jerzeejay wrote: Tue Apr 05, 2022 1:27 pm
-Ed
Start a thread or pm me.
-Ed
