ANYONE CAN HELP ME SET UP A BASE MAP FOR K24/K20 TURBO
emzzie012
Post by emzzie012 »
LOOKING FOR A BASEMAP FOR K24A2BLOCK/K20A2HEAD TURBO (STOCK BLOCK AND SUPERTECH HEAD PACKAGE AND ARP HEADSTUDS)
ID1000CC INJECTORS,PRECISON 6266 TURBO, 4BAR MAP SENSOR, 44MM TIAL WASTEGATE 7PSI SPRING
JUST NEED HELP TO GET MY CAR STARTED TO TEST IT OUT TO MAKE SURE THERE'S NO LEAKS BEFORE I GET IT TUNED.
emzzie012
Re: ANYONE CAN HELP ME SET UP A BASE MAP FOR K24/K20 TURBO
Post by emzzie012 »
THANKS IN ADVANCE
CalibratEd
Post by CalibratEd »
I can help out. Does the car have a working IACV?
-Ed
Instagram: calibrated.tuning
emzzie012
Post by emzzie012 »
yes it does have IACV
CalibratEd
emzzie012 wrote: Fri Jan 21, 2022 6:04 pm yes it does have IACV
What ECU are you running and do you have a working wideband?
-Ed
emzzie012
Post by emzzie012 »
Pnd hondata kpro v4 and i dont have a wideband yet
But i can use the hondata app on my phone
CalibratEd
Give this a try. Let me know if it starts and if you can get it to idle. If the car is able to idle send me a datalog of it at idle after it has reached operating temperatures. If you can drive it around even better. The map should run rich. I can lean it out after a few revisions.
- Ed
emzzie012
Post by emzzie012 »
thank you so much for your help @CalibratEd i will update you once i get the car started and send you datalog
i apreciate your help man.
CalibratEd
emzzie012 wrote: Sat Jan 29, 2022 7:00 pm thank you so much for your help @CalibratEd i will update you once i get the car started and send you datalog
No problem.
-Ed
emzzie012
Post by emzzie012 »
here's the datalog idling and rev
emzzie012
Post by emzzie012 »
idling and driving
emzzie012
Post by emzzie012 »
CalibratEd wrote: Fri Jan 28, 2022 9:11 pm Give this a try. Let me know if it starts and if you can get it to idle. If the car is able to idle send me a datalog of it at idle after it has reached operating temperatures. If you can drive it around even better. The map should run rich. I can lean it out after a few revisions.
- Ed
here are the datalogs
thanks CalibratEd
CalibratEd
emzzie012 wrote: Fri Feb 04, 2022 8:25 pm
- Ed
thanks CalibratEd
Seems to be running a lean. I added more fuel. Load the revised file and Create a similar datalog.
Jerzeejay
Post by Jerzeejay »
CalibratEd wrote: Thu Jan 20, 2022 9:29 am I can help out. Does the car have a working IACV?
-Ed
Hey I’m in need of similar help with my k24/20 help and I’m in the sticks pm me or ig message jjerzee
CalibratEd
Jerzeejay wrote: Tue Apr 05, 2022 1:27 pm
-Ed
Start a thread or pm me.
-Ed
