cylinder#2 no spark
Toohott00
cylinder#2 no spark
Post by Toohott00 »
I had a running car with a working OEM distributor I installed the retrofit by the instructions to the letter that are in the s300 software.
The car starts but I have zero spark on number 2 cylinder. I have swapped coils, plugs. Work on every other cylinder but not # 2.
The box has power. Ignition light is working and the sync light is also working as well.
Swapped in a "known" working CPR ECU and still same issue with no spark cylinder#2
The option in the Misc. section for the CPR was uploaded and checked on during testing.
Went back to the distributor setup, works great.
Please looking for suggestions as I think I have exhausted every option that I have read and researched on the forums or can think of.
Appreciate the help.
Re: cylinder#2 no spark
Check the continuity of the wires for that coilpack from the coil end to the CPR.
Toohott00
Post by Toohott00 »
there is continuity
Toohott00
Post by Toohott00 »
I opened up the back of the CPR unit. This is what I found Image
Something appears to have been wired incorrectly which caused the chip to burn. The board will have to be replaced.
Send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
