Page 1 of 4
S300V3 / P28 ECU issues
Posted: Thu Dec 16, 2021 3:08 pm
by kraquepype
Hello, I've had sporadic issues with my S300V3 on my P28 ECU. I'd like to understand more if I should suspect the S300 module or the ECU.
1) First is the O2 reading, its stuck at 3.8v and sometimes jumps all over the place. I had a thread here: http://www.hondata.com/forum/viewtopic.php?t=24856
2) There is also sporadic limp mode, if you can call it that. Sometimes after starting the car (usually warm) it will cut out and feel like its hitting a fuel cut. After waiting a few minutes its fine. I have not been able to log the issue.
3) Speaking of logs, datalogging is hit or miss. I am using the SCS jumper as the trigger for the onboard datalogging, and lately I get a lot of corrupt or empty logs. This is making it hard to fine tune.
4) Sporadic corruption - sometimes the ECU will get into a corrupt state and requires a re-write of the calibration to clear it up. Online datalogging also returns corrupt information in this state, showing 20k RPM and 1000mph readings for example.
How can I rule out the S300 and/or ECU? I wanted some input before I get into repair/replacement/etc of parts.
I am using resistor plugs and NGK plug leads, stock ignition.
Re: S300V3 / P28 ECU issues
Posted: Thu Dec 16, 2021 3:47 pm
What is the serial umber that is on the s300 board inside the ECU?
Who socketed your ECU?
Posted: Thu Dec 16, 2021 7:43 pm
by kraquepype
The number on the box is 42965, its handwritten so I assume thats the serial. I'll have to take it out of the car if that isn't it.
Version of SManager is 2.7.7.0
HAMotorsports sold me the ECU/S300v3 together as a package.
Posted: Fri Dec 17, 2021 10:18 am
Have the capacitors been replaced in the ECU?
Posted: Fri Dec 17, 2021 11:32 am
by kraquepype
It was an HAMotorsports ECU, they are supposed to replace them.
Could this behavior be explained with failing caps? I can always recap it again myself.
Posted: Fri Dec 17, 2021 12:45 pm
Its a possibility, if they were not replaced, or are faulty.
Posted: Mon Dec 20, 2021 8:42 pm
by kraquepype
The caps all look new and seem to be good. There was one pin on the latch chip that looked suspect, I reflowed them all. Still no difference really.
At this point I'm willing to try another ECU and see if I can rule it out.
I did get to drive it tonight and I went through my normal issues. It starts, idles, fine, even in the cold. I had adjusted something in the datalogging and I guess the calibration upload corrupted something. It goes into what I call limp mode but it feels more like a fuel cut - if I go past a certain amount of load the engine feels like it hits a fuel cut and the AFR leans out. I limped it over to a spot I can look at it, and after shutting off / re-uploading and restarting it was fine. The problem with this is I can't really tell it has this issue until I start driving, and by the time I notice its a nerve wracking experience of pulling over and fixing it.
The car drives and feels great overall afterward. I picked up dinner and heading out I hit the fuel cut / limp mode again, but this time I got a datalog of it. The issue clears after a few seconds and it responds normally again. Its really bizarre.
The datalog shows a spike where everything goes crazy, there shows to be a drop in voltage to 8v, which might explain why the readings are so whacked out. I will try to see if theres a wiring issue next time its warm out.
Another oddity is with datalogging. I noticed that time moves twice as fast in my datalogs - for example if I enable onboard logging for 15 seconds, it records a 30 second datalog. I don't know if its normal but right now its just another issue on top of my growing list.
I've attached the datalog that shows the spike and voltage drop.
wtf_1.s3d
Posted: Tue Dec 21, 2021 10:20 am
Does it do this if you datalog directly using the laptop?
Posted: Wed Dec 29, 2021 4:51 pm
by kraquepype
Hi, logging via the cable works as expected, no issues.
I drove it recently and encountered the limp mode / hesitation, and this time when I enabled datalogging the ECU logged multiple rev limiter logs. I've attached the datalog.
There was no voltage drop this time, and I have no settings that should be triggering a rev limiter at such a low RPM - the datalogs look normal except for the rev limit, but maybe I'm not looking in the right places.
This clears within a minute and the car behave normally.
Posted: Mon Jan 03, 2022 10:25 am
What frequency do you have on-board datalogging set to in your calibration?
Post the calibration that the datalog was made with.
Posted: Tue Jan 04, 2022 7:43 am
by kraquepype
Sure, I've attached it.
b16b_rdx.skl
Posted: Tue Jan 04, 2022 10:17 am
Try setting the on-board datalogging to 25 Hz.
Posted: Wed Jan 05, 2022 1:29 pm
by kraquepype
I neglected to mention, I tried the frequency at 15 and 25hz and it was the same result.
Still waiting on a cap kit and might try replacing the latch chip, not sure what else to do. Is there any places in the calibration I should look at for why the rev limiter was triggering?
Posted: Wed Jan 05, 2022 2:03 pm
If you unplug the analog input to the s300 does the problem persist?
Posted: Wed Jan 05, 2022 2:09 pm
by kraquepype
No analog inputs are hooked up right now, I assume you are referring to the 2246 sensor enabled in the analog inputs... I was planning on setting those up but haven't yet and I guess I saved a calibration with it by accident. It shouldn't be a problem to have it enabled in the calibration right?
