Racepak IQ3 with Universal CAN EFI adapter info
Posted: Thu Dec 16, 2021 12:58 pm
by Garrett_si
Hi Hondata, in the past Racepak has a Hondata Kpro adapter for the CAN communication with the Kprov4. They obsolute it, but now the Universal EFI CAN adapter don't have the Hondata ECU un the drop down menu. They tell us to contact you to have the protocol. and telling us what ECU choice we could use.
thanks you very much for help
Re: Racepak IQ3 with Universal CAN EFI adapter info
Posted: Thu Dec 16, 2021 1:57 pm
Our protocol is documented here:
http://www.hondata.com/help/kmanager/can_output.htm
and
http://www.hondata.com/help/kmanager/can_output_2.htm
They don't list the KPro; I'm not sure if they support it.
Posted: Fri Dec 17, 2021 1:09 pm
by Garrett_si
since they said me to make it user configurabled, I put it.
When I configure each channel, I don't find the same info has the help file you share me.
how could we choose the right info for the channel, if you have 4 channels in the same ID?
I attached a screenshot of the X660 Vnet ID from Racepak
thanks a lot
Posted: Fri Dec 17, 2021 3:08 pm
It looks like the CAN IDs are fixed and there's no way to divide each packet into bytes.
What software is the screenshot from? I will have a look.
Posted: Mon Dec 20, 2021 8:16 am
by Garrett_si
this is in the Racepak DatalinkII software. https://documents.holley.com/techlibrar ... 4.8.12.zip
do you have more info, how they are divided in your protocol?
thanks a lot
Posted: Mon Dec 20, 2021 10:23 am
The packets are described in the link above.
http://www.hondata.com/help/kmanager/in ... output.htm
Without the hardware I cannot connect with the software to see what the packet description method is.
Posted: Fri Jan 17, 2025 3:41 pm
by skunk2dc2
Is there an update on this I have a Racepak IQ3 wires to my Hondata S300, I’m having no luck to finding a way to program the universal interface
