CAN Bus Feature Add-on
Posted: Thu Dec 09, 2021 7:04 am
With the extremely limited limited number of IO ports on this platform's ECU what are the odds of adding support for a CAN bus breakout board to add IO for things like a flex fuel sensor, boost solenoid, traction control input, and wide band sensor? You know the staples of the Hondata platform.
Taking it a step further this could be a gateway for engine swaps that need AC compressor control.
Is that something terribly hard to add to the code? Probably something many other Honda platforms of this generation and newer could benefit from.
I am pretty well versed in CAN bus. I have produced several CAN adapters for various Honda swaps for fully integrated swaps that function like factory. I would be willing to lend a hand on a project like this.
If nothing else maybe a developer mode that is able to add CAN messages and is decently documented to let the enthusiast community run wild with developing applications.
Thanks for your consideration!
