civic cvt Speed limit problem
Posted: Thu Dec 02, 2021 12:19 am
by cyh60108
I CVT use the + 6psi program. When the speed reaches 204kph, the fuel is cut off. Can the limit be lifted.
Re: civic cvt Speed limit problem
Posted: Thu Dec 02, 2021 10:31 am
It can be changed in the rev limits section of the calibration window.
Posted: Thu Dec 02, 2021 5:39 pm
by cyh60108
Spunkster wrote: Thu Dec 02, 2021 10:31 am It can be changed in the rev limits section of the calibration window.
I changed the speed in the calibration window to 7000 rpm and the speed limit to 300kph. However, the oil supply is still 204kph cut off. Is it because I'm a Chinese car?
Posted: Fri Dec 03, 2021 10:38 am
I'm not sure what you mean by the oil supply
Posted: Fri Dec 03, 2021 12:55 pm
by cyh60108
Spunkster wrote: Fri Dec 03, 2021 10:38 am I'm not sure what you mean by the oil supply
After the speed limit in Flash Pro has been modified to 250kph, the speed will not increase when it reaches 204kph, and the turbocharger stops working.
Posted: Fri Dec 03, 2021 1:11 pm
Post the calibration as well as a datalog showing the issue.
Posted: Fri Dec 03, 2021 8:01 pm
by RedYung
I think he means fuel supply.
Posted: Fri Dec 03, 2021 8:49 pm
by cyh60108
Spunkster wrote: Fri Dec 03, 2021 1:11 pm Post the calibration as well as a datalog showing the issue.
I asked the dealer who bought hondata and told me that the TCU of CVT limited the speed. Hondata flash Pro could not modify the TCU, but only the ECU
