Hello,
i just received my brandnew kpro v4. Cant wait to install it.
But i have a question, i need to connect some analog inputs (Oilpressure, Oiltemp, Fueltemp and Fuelpressure). Also i need to connect my dashboard via the canbus.
With the package there were two cableextensions with a connector on one end. I assue this is the wireing for the analogue input or maybe even canbus. But where to connect it to? I guess the plug is on the kpro unit itself, but i have stickers over the ecu case, saying that i dont have a warranty anymore if the stickers are void, so i cant open it..
Some explanation would be gold! :)
Thanks!
Greets from germany.
Where to connect Analog input and CANBUS
Re: Where to connect Analog input and CANBUS
The ECU will have to be opened to connect them and wire them correctly.
See the help file:
http://www.hondata.com/help/kmanager/an ... sub=analog
http://www.hondata.com/help/kmanager/di ... ub=digital
See the help file:
So the warranty wont be void if i do?Spunkster wrote: Wed Dec 01, 2021 3:40 pm The ECU will have to be opened to connect them and wire them correctly.
See the help file:
No, as there is no other way to connect them.
perfect, thanks
