k pro/kmanager issues
Doughjangles
Post by Doughjangles »
- 1998 honda civic cx
- ECU part number 37820-PRB-A08 SN 2068-800723
- KManager version 4.4.9.0
- k24a2 swapped with ktuned engine and chassis harness
- Bought the kpro off a seller on ebay about 2 years ago, just recently got around to installing it.
- Car was recently put together and was running fine for a couple days, now it cranks and doesn't start. Laptop connected to k pro says "Driver installed, Online and ignition off" even when the key is turned on, so I cant change anything in the k manager software. Checked for green light on the hondata board and it comes on for about 2 seconds and then turns off and there is only a dim flashing red light when connected to laptop. Car will almost start when green light is on and then will just crank, no start when the green light shuts off. Checked for power and grounds going to ecu and everything checks out fine. Wondering if the ecu needs to be sent in to be repaired? Thanks.
Re: k pro/kmanager issues
Try the ECU on a known working vehicle and see if it sees the ignition turn on.
Doughjangles
I don't have access to an rsx or another k swap car to test it unfortunetly..
You need to try to find one locally as this will tell you where you need to look further.
Doughjangles
Found a local running k swap car, I was able to plug my ecu into and it does the exact same thing.
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
K24ADB8
Post by K24ADB8 »
What was the ending solution? I am having the same issues with my V4
please start your own thread
