FlashProManager 3.8.4
Posted: Thu Oct 21, 2021 9:25 am
V3.8.4 (20 October 2021)
• Firmware updated to version 204
• Fixed slow BlueTooth datalogging for some vehicles
• [2016+ Turbo Civic] Added support for Europe 2019 model 5AN-E41
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Re: FlashProManager 3.8.4
Posted: Sun Oct 24, 2021 5:26 pm
by Garrett_si
we send you an email about that this week, you said no issue with 3.8.2 and 3.8.3
So we tuned a FK8 on 3.8.3 ( about all 0 fuel trim, and 0 LTFT), since the new update 3.8.4 was release friday we updated. And now LTFT are 25%.
Posted: Mon Oct 25, 2021 4:08 am
Please provide details. Are you using the fuel system and/or different injectors? What about providing the calibration?
Posted: Sun Oct 31, 2021 5:27 pm
by 540999115@qq.com
Live tuning still doesn't work for China 5AF-CH1 in 3.8.4,sensors-AFM tuning.
Posted: Thu Nov 04, 2021 4:05 am
by RedYung
I noticed some ignition tables has been removed. Ignition table low/high, knock retard low removed.
The ignition and knock control now left with only few tables to adjust.
Is it because of my FlashProManager settings or Hondata has removed them ?
Posted: Thu Nov 04, 2021 9:17 am
Please provide details. What vehicle? Can you provide a calibration?
Posted: Fri Nov 05, 2021 2:13 am
by RedYung
Hi Hondata,
My calibration detail below. You can see that there are no additional ignition tables and knock control tables. I remembered last time I used to have them, but I can't recall since when they disappeared. There are no more adjustment tables for per cam degree ignition timings and etc..
Posted: Fri Nov 05, 2021 9:08 am
That model has the same tables as any other CVT. No tables have been removed.
Posted: Wed Nov 10, 2021 8:32 am
by Emount91
only noticed this after reflashing the car with the 3.8.4 software:
My check engine light comes on after the reflash and stays on for 3 engine cycles. When I try and run the code it says there is no check engine light on, and when I try and manually clear it it doesn't work. no historical codes either.
Only after that 3rd ignition turnover after flashing does the CEL finally go away. I haven't experienced this issue with any former updates, not sure if this is normal or not even an issue. Just something I noticed. (recreated it with 2 reflashes so far)
Posted: Fri Nov 12, 2021 7:51 pm
by H.turbo
I have this same problem but i had the shop pull my codes and they are actually transmission codes. All of this happened after the new updated flash . I think it’s because the flash pro is reading trans temps. I don’t know for sure but it seems like the flash is the reason why.
Posted: Sat Nov 13, 2021 9:40 am
by Emount91
H.turbo wrote: Fri Nov 12, 2021 7:51 pm I have this same problem but i had the shop pull my codes and they are actually transmission codes. All of this happened after the new updated flash . I think it’s because the flash pro is reading trans temps. I don’t know for sure but it seems like the flash is the reason why.
The CEL goes away after 3 ignition cycles for you too right? Car doesn’t seem to be driving any differently than it should, was just very concerning the first time it happened because I had to make a 60 mile drive to work after a reflash. I wasn’t sure if I was damaging my engine somehow, and the Hondata app wasn’t even recognizing the CEL.
Posted: Sun Nov 14, 2021 6:52 am
by H.turbo
Yeah the app doesn’t pick up the code because it’s transmission related I think . I haven’t done 3 ignition cycles yet nor put some miles on the car yet . I’m pretty sure everything is fine with the car. The CEL is really concerning though.
Posted: Tue Nov 16, 2021 5:48 am
by H.turbo
Any insight @hondata ?
Posted: Tue Nov 16, 2021 8:45 am
Please start by telling use what vehicle you have, what error you are getting and provide the calibration and a datalog.
Posted: Wed Nov 17, 2021 10:00 am
by H.turbo
I have an civic hatch sport . My car is in the shop for some bodywork but the codes that came up or transmission related instead of engine related. I believe that one of the codes mentioned a connection interruption with the transmission module. After I flashed the new tune with the update the check engine light appeared. Whenever I get my car back I will be sure to send a data log in.
