Rev limit when vtec pops
LsvturboDa
Post by LsvturboDa »
Lsvtec turbo da pulls all the way threw when vtec is not engaged but once vtec is engaged it hit some sort of rev limiter/breakup. Vtec is set at 5500 rpm
Re: Rev limit when vtec pops
More than likely your grounds in the engine bay are not correct and it is grounding through the VTEC solenoid. Pay special attention to the thermostat housing ground.
LsvturboDa
Update everything works correctly with stock map sensor..
LsvturboDa
Am running a skunk2 4 bar map sensor but for some reason will not pop vtec with it installed.
Post the calibration and a datalog showing the issue.
LsvturboDa
vtec breakup.s3d
DA.New.Setup.V2.Rev7.skl
There are no rev limits, boost cuts, or ignition cuts in the datalog. There is some other cause other than the ECU.
Are you using resistor or non-resistor type spark plugs?
LsvturboDa
Ngk 4554 gapped to 15 thousands
LsvturboDa
If it was something mechanical why would it work with the stock map sensor ?
Those are non-resistor plugs and should not be used. You must use Resistor type plugs.
LsvturboDa
Which plugs work best it is a lsvtec on 20 psi?
LsvturboDa
Still doesn’t make sense why everything works with stock map sensor ? I would think if it was a spark plug issue it would do it regardless of what map sensor I use.
