96 Integra k20a2 5 speed base map kal
k20a2DC2
Post by k20a2DC2 »
What's the best base map .kal to start my car and use to get the car to the tuner?
Also looking for correct readings for sensors whether its temperature, voltage, percentages I want to compare my readings
No check engine lights except for the secondary oxygen sensor which is turned off
If anyone has a similar set up please send your kal Ill pay for help.
IG ekracer98
CAR:
1996 Acura Integra LS OBD2 Kswap 5speed
Engine 02 RSX Type-S K20a2
Transsion 02 Civic SI 5 speed (No reverse Lockout)
ECU Civic Si 37820-PNF-A11 Hondata Kpro V4 Whiteboard V4.4.9
The engine has ARP head studs drag cartel crank chain gear, Drag cartel chain, guard.
New gaskets, seals, o-rings (complete engine)
New NGK 6988 BKR7EIX-11 Laser Iridium IX Spark Plugs
Hasport swap axles, Action clutch lighten flywheel
Intake/Exhaust Manifold:
RBC intake manifold, Stock Type-S throttle body, with IAC
Karcepts throttle body adapter
Thermal gaskets at the throttle body and intake/head
AEM 3.5 bar map sensor, Stainless version
k-Tuned swap header, to 2-1/2" exhaust (NO-CAT)
02-04 RSX -S primary 02 wideband #234-9005
AEM wideband 4110 Installing now also
Oil pressure, Oil temp, Water temp, gauges
Fuel System:
Karcepts fuel rail
fuel injectors stock RSX 310cc
AEM 340 Fuel pump With relay 14v
Fuel feed and return -6AN Braided Hose (Should I change to PTFE hose -8AN Feed -6AN Return)
Fuel pressure regulator with gauge Summit Racing Branded
Fuel pressure set at 50 PSI
Cooling:New OE replacement thermostatNew OE replacement water pumpKoyo radiator full-size12" Fan Pusher/Puller
Not installed parts yet:ktuned throttle body 70mmAEM wideband 4110Hondata analog cable
k20a2DC2
Re: 96 Integra k20a2 5 speed base map kal
Post by k20a2DC2 »
No one has anything similar? not one person?
