Closed loop target lamba
Posted: Mon Oct 04, 2021 1:14 pm
by 08FitSport
I have a question concerning closed loop target lamba. In the parameter I have changed the target lamba to 15.3. Also edited the target lambda limit, closed loop target lambda low and high in the same range. I am trying to get the ecu to target a afr of 15.3 to see is I can increase the fuel economy a good bit. After making all those changes the ecu is still targeting 14.7. Any ideas?
Re: Closed loop target lamba
Posted: Mon Oct 04, 2021 4:38 pm
post your calibration and the datalogs made using that calibration.
Posted: Tue Oct 05, 2021 11:26 am
by 08FitSport
Here you go.
Posted: Tue Oct 05, 2021 11:52 am
I will have our software engineer take a look at this.
Posted: Tue Oct 05, 2021 12:28 pm
by 08FitSport
You see what I am talking about. All the target parameters are set for the ecu to command 15.3 ecu stay at 14.7. Everywhere else its fine.
Posted: Wed Oct 06, 2021 4:30 pm
by 08FitSport
any news on the target lambda?
Posted: Wed Oct 06, 2021 4:51 pm
Not until we have a vehicle to test on.
Posted: Mon Oct 11, 2021 4:03 pm
It does not appear that you can target leaner AF ratios beyond 14.7. Only richer ratios to 13.12 can be reached.
Posted: Tue Oct 12, 2021 9:36 am
by 08FitSport
that is for this application? i heard that some ecus on flashpro will not allow you to run leaner then 14.7. Would adding a external wideband allow you to achieve leaner AFRS in part throttle range using widebank closed loop control?
Posted: Tue Oct 12, 2021 10:02 am
No this is not possible. You can only do this in open loop.
Posted: Tue Oct 12, 2021 11:21 am
by 08FitSport
Not sure what you mean by only in open loop
Posted: Tue Oct 12, 2021 11:29 am
You will only be able to run leaner in open loop as it will not try to target a specific AF ratio.
Posted: Tue Oct 12, 2021 12:43 pm
by 08FitSport
so basically wideband closed loop does not work with this ecu?
Posted: Tue Oct 12, 2021 3:55 pm
IT does work, you just can't force it to run leaner in closed loop.
