D16z6 vtec .050 Vitara Turbo Base Map
Posted: Thu Sep 30, 2021 11:25 am
by NateCross
Picked up this build recently, installed the s300 and pwm boost control. It was just socketed with a manual boost controller. I basically just copied the build sheet from what I was given. Just need a base map to get it running, but I am having a heck of a time finding data for these injectors, and I'm not 100% on getting things set up for the stroke and cam. I would appreciate any help with a base map, it will be dyno tuned once I get it started.
D16 z6 vtec.050 Vitara build J spec billet rods. Block decked, ported Y8 head, new valves and springs for cam. Delta 2.4 bisimoto cam, reground followers, Arp head studs, .020 Aem cometic head gasket, Aem cam sprocket. Skunk 2 intake, 68 millimeter throttle body, 540 precision injectors, Aem adjustable fuel regulator, Aem billet fuel rail, 255 walbro fuel pump, Turbo techtonics blow off valve, T3/T4 turbo 55.8 mm, spoolin performance turbo manifold, Turbo smart 38mm waste gate, hondata 4 port boost control solenoid, 2 1/2 inch exhaust. Four bar hondata map, s300 p28 ecm. Turbo timer. Msd blaster coil and dizzy cap and rotor, new distributor.
Re: D16z6 vtec .050 Vitara Turbo Base Map
Posted: Mon Oct 04, 2021 2:37 pm
by NateCross
Managed to find injector data if anyone is interested in getting a base map set up.
