Hey guys,
I have a SpeedFactory 3 Bar Map Sensor that I am installing. When I go into Smanager, does it matter which brand of "3 Bar" that I choose? I see Motec, Neetronics, & MSD. No SpeedFactory, so which do I pick?
The reason I ask is because on the SpeedFactory Data Sheet from their site it says to change:
Scalar to : 617
Offset: 11
But, when I change the offset it change the type of Map sensor to "custom" under the dropdown.
Is this supposed to happen??
SpeedFactory 3 Bar Map Sensor Quetions
G. Wiffington
Re: SpeedFactory 3 Bar Map Sensor Quetions
If it's not in the dropdown and you enter custom parameters then yes, it should say custom.
G. Wiffington
Thank you!
I just wanted to make sure.
Will respond back with results. I just installed my Walboro 255.
G. Wiffington
Just an update, I installed the SpeedFactory 3 Bar Map Sensor along with my 255 Walboro.
Car started great, just had to add a small bit of fuel overall. Haven't drove on it yet but everything seems great in regards to AFR's & how it starts & idles.
