HKS Racing Suction intake calibration
Patrickva92
Post by Patrickva92 »
So I just purchased the HKS racing suction intake w/o AFR and I’m curious what the proper calibration would be, since I don’t see options for this particular intake under the modifications list. Would I just select the option to remove the p0101 & p0103 codes or Is the only option a custom tune?
Re: HKS Racing Suction intake calibration
P0101 and P0103 means the AFM is not measuring the air corrected. You can remove the error codes but that does not fix the underlying problem.
anthonyfa18
Post by anthonyfa18 »
Dose hondata have a base map for this intake with carbon box, we are having an issue same issue on the car ???
We only have the calibrations listed in the New Calibration window. You can also search the Vault for calibrations that others have uploaded, or contact your dealer/tuner to see if they can help you with a basemap.
anthonyfa18
I really hope you will one day make a base map for Hks parts
