Cannot lock ecu to flash pro
FlashPro questions & answers specific to the 2007-2008 Acura TL
jasonvictory86
Post by jasonvictory86 »
I have a 2003 Accord V6 6MT with a boomslang harness and a84 ecu.
I can access the ecu through Honda HIM and HDS but flash pro manager has red x through ECU and OBDII.
I double checked the can wiring is connected right (behind the passenger airbag and then to the dtc).
I synced the immobilized as well through HDS.
Any ideas why the flash pro won’t read the binary data and the VIN? The ecu has a 2008 VIN code into it through HDS. I could change it to my 2003 accord Vin if needed.
thanks!
1991 Honda Beat PP1. Coilovers, Ray's 14" Rims, Roll Cage.
Re: Cannot lock ecu to flash pro
If you plug the FlashPro into any other FlashPro supported vehicle, does it show green checks for everything at the bottom of the screen with the ignition on?
jasonvictory86
The only other car I have is a 2019 Honda Fit.
Try it and see what it shows.
jasonvictory86
Same thing.
ECU
i- OBDII: Not Connected
i- VIN: (blank)
i- Calibration ID
i- CVN 0xFFFFFFFF
!- Binary: Unknown
open the FlashPro and take a picture of the inside and post it here.
jasonvictory86
Let me know if you want to see another picture
shows the immo is synced
jasonvictory86
It’s a brand new unit bought off the website. Not used or second hand if that makes a difference.
I have HDS loaded on my laptop. If you want I can take screenshots of that.
The biggest thing is that I put RDX injectors in it so I can’t start the car even to back it out of the garage.
You have not posted a picture of the inside of the FlashPro itself.
jasonvictory86
Oh, like physically inside the flash pro unit?
yes
jasonvictory86
Where was the harness you are using purchased from?
jasonvictory86
Boomslang. Cost me $600 and bought it brand new
Send an email to support<at>hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread
