Help with Calibration Turbo lsvtec
codyhonda
Post by codyhonda »
Here is my current tune for my LSVTEC 550 cc injectors, 57 trim . Looking to see if anyone thinks these fuel tables could be smoothed out for a little better driving ? My timing maps should all be good , just need assistance with the fuel. Under part throttle my afrs are pretty bad and seems pretty difficult to get it right with wideband as i keep getting false readings from letting off throttle in that area .
This is my first tune and under WOT the car is running pretty good. Just alot of part throttle work to do and maybe lean out a little more at WOT.
My tune is attatched and please keep in mind this is my first tune. My idle is also a little wonky, seems to jump around a little bit and almost wants to die but doesnt ( i think from being lean but has plenty of fuel at idle )
tonaatwood
Re: Help with Calibration Turbo lsvtec
Post by tonaatwood »
I would like to know the answer to this question as well.
Boostedintegra
Post by Boostedintegra »
I can help you out with an etune if you can provide logs with a wide-band logged to the ecu and threw email or team viewer
IBukNoy
Post by IBukNoy »
Could I ask? What did you set your base ignition timing to before you started your base map?
