Page 1 of 7
quick help cleaning up a tune
Posted: Wed Aug 18, 2021 12:17 pm
by CJones7566
Hi i have an 08 civic si with a psuedo 70 mm cat back and a ported intake manifold, mishimoto silicone intake tube, k and n drop in filer with ice box to front fender, the tune im using is for 70 mm and was ... so its not perfect, any help would be great
Re: quick help cleaning up a tune
Posted: Wed Aug 18, 2021 12:18 pm
by CJones7566
shoot also exedy light weight fly wheel if that matters at all for smoothing fuel
Posted: Wed Aug 18, 2021 12:50 pm
by EFICU
Are you using cruise control/speed control at any point in this datalog?
Posted: Wed Aug 18, 2021 2:18 pm
by CJones7566
yes dang itt i knew that would be an issue i used it every 500 rpms after WOT pull, what do i need to do instead just hold rpm with throttle?
Posted: Wed Aug 18, 2021 2:34 pm
by CJones7566
if I need to do another log I will, right meow, if i did it wrong someone let me know , my 1 year old wants to go do some pulls
Posted: Wed Aug 18, 2021 2:41 pm
by EFICU
I was curious because of how you had 0% throttle pedal but the throttle plate was open 19% or so.
The calibration you're using is too much for your setup, which I know because it's my calibration. If you want help tuning it for your setup I can help you with it. But I would start you on a different file to get started and dial it from there.
Let me know and I will send over the first file for you.
Posted: Wed Aug 18, 2021 3:39 pm
by CJones7566
sure please send it, thanks, may have some noob questions but lemme try it out!:) was my data log ok? should i log the same way with this new map?
Posted: Wed Aug 18, 2021 3:50 pm
by EFICU
Yeah no problem, let me know whatever questions you have as we go.
Here is the first calibration for you. We need the datalogs to be 20-30 minutes in length with as much stop and go type driving. While on the drive, make one wide open throttle (WOT) pull from 2500-8600 so we can see the WOT fueling. Only do one WOT pull until I can clean up any big chunks in the next revision for you. Then you can have more fun with it. It will be close to start, but I don't want you to go out there and get too aggressive with it before we see how it looks.
CJones7566.Hybrid.Rev01.fpcal
Posted: Wed Aug 18, 2021 4:00 pm
by CJones7566
awesome I will data log tonight and do these things, your a beast man thanks!
Posted: Wed Aug 18, 2021 4:30 pm
by EFICU
Sounds good. We'll see how it looks.
Posted: Wed Aug 18, 2021 5:44 pm
by CJones7566
Here it is, would I do better on no ethanol 92 or regular 92 ? Also I use this car for dd but also go hard on mountain roads, 6 30 min rips a week so feel free to make it a little on the aggro side
Posted: Wed Aug 18, 2021 6:03 pm
by EFICU
It wouldn't make too much of a difference with or without ethanol. For NA setups, ethanol doesn't make too much of a difference.
With your setup there isn't too much we can do to make it more aggressive. Your car already shows knock with the ignition that is in it up top so I had to pull some back. Once you do a race header and an intake like an HR or Skunk2 it would really open up. I changed the pedal map to my sport pedal, that might make it feel a little sportier, but I can only do so much with it all before knock shows up which you really don't want on your mountain runs.
Take this one for a spin and see how it feels. Drive it however you want, but be sure to get at least one clean pull in third gear from 2500-8600 and be sure the datalog is between 20-30 minutes. I raised the rev limiter up to 8600, I had it at 8300 on that first one, sorry about that. But feel free to drive it however you want, just be sure to get that clean third gear pull.
CJones7566.Hybrid.Rev02 (SportPedal).fpcal
Posted: Wed Aug 18, 2021 6:10 pm
by CJones7566
I kinda figured but didn't know how much potential was held back by stock tune, sounds great I'll upload a data log tonight or in the am, I plan on building it fully over time, it will become race car, and never be sold, but I just got flashpro and needed to get a solid tune, I'll try it out thanks again
Posted: Wed Aug 18, 2021 6:14 pm
by EFICU
Sounds good. It should be just about dead on in this one. The part throttle fuel trims were great, and the WOT fueling only needed a few adjustments. Yeah the cat is the biggest restriction, once you get the race header in there and the intake it really opens up with the right tune. It's pretty crazy to see how much they open up with a race header and a 3.5" intake. Biggest thing with your mods now is not asking too much for cam angle with your intake and OEM cat. Too much VTC and it loses power. You should like it with the sport pedal, sounds like you like to get after it sometimes.
Posted: Wed Aug 18, 2021 6:18 pm
by CJones7566
Every day its driven hard, me n my g pa bought it in modified at dealer;he died;the car will live on and become gutted and built, thanks again bud
