K24a MR2 Spyder Tune
Posted: Thu Aug 05, 2021 12:02 pm
by K24MRspyder
Hey guys, new to this forum but forums in general. Just wanted to introduce myself and ask for assistance if possible. I just finished swapping a k24a (jdm k24a2) into my toyota mrs, im still awaiting a PLX wideband to come in. Mods are intake/header/exhaust and most likely my bigger issue 70mm skunk 2 throttle body. Currently I can use a stock basemap from hondata and the car will start and run great with a slightly high idle. Once warm the vehicle will start to surge from 1200-2000 rpm and smells very rich. I dont know the A/F yet due to awaiting the wideband. When I partially cover the throttle I can get the car closer to a normal idle so im thinking its with the tune. Any assistance would be greatly appreciated. Thanks all!
Re: K24a MR2 Spyder Tune
Posted: Thu Aug 05, 2021 12:24 pm
IT sounds like there is an air leak.
Have you tried adjusting the idle parameters?
Have you checked for leaks?
Have you tried cleaning the idle controller?
Posted: Thu Aug 05, 2021 1:14 pm
by K24MRspyder
No air leaks that I can find. The throttle body is a bit bigger compared to the 63 that it comes with.
Posted: Thu Aug 05, 2021 1:28 pm
by K24MRspyder
I did change the parameters as well. It idles nice when cold.
Posted: Thu Aug 05, 2021 3:22 pm
It sounds like an air leak, or you could also have bubbles in the cooling system.
Posted: Thu Aug 05, 2021 8:03 pm
by K24MRspyder
I think I found the leak. Very small though. Also, I was reviewing the other threads with the PLX Wideband install and you guys reference a wiring diagram but everytime I click the link it says error.
Posted: Sat Aug 07, 2021 9:23 am
by byk24mr2
I have a similar setup. My airleak was from a MAP port on the throttle body itself that needed a plug.
Posted: Sat Aug 07, 2021 7:02 pm
by CalibratEd
K24MRspyder wrote: Thu Aug 05, 2021 8:03 pm I think I found the leak. Very small though. Also, I was reviewing the other threads with the PLX Wideband install and you guys reference a wiring diagram but everytime I click the link it says error.
http://www.hondata.com/help/kmanager/in ... inputs.htm
-Ed
