Page 1 of 2
04 EP3 Jdm K24a K-Swap
Posted: Tue Aug 03, 2021 4:10 pm
by jdmalex313
I have a 04 Honda Civic Hatchback Si & Recent Swapped The Original K20a To A K24a.
Once I Turned On The Vehicle It Work Decent But Once I Started Driving It Unfortunately Doesn’t want To go over 3,000 rpms
At first I had thought it was my timing valve oil pressure sensor took that off the K20 & put it on the K24a & still didn’t wanna go over 3,000. My Air intake I had was kinda beat up so I assumed it was sucking up more air than it suppose to, so I brought an new air intake worked a lot better but still doesn’t go over 3,000, my last option is my ECU. I’m interested in sending my ECU too Hondata if that’s the issue.
Codes that showed on screen were oxygen sensors (that I don’t have anymore) & Oil Pressure sensor that’s been replace with the K20a
Re: 04 EP3 Jdm K24a K-Swap
Posted: Tue Aug 03, 2021 5:25 pm
Do you have a Hondata system?
Posted: Tue Aug 03, 2021 5:35 pm
by jdmalex313
Im trying to get one point me to the right direction
Posted: Tue Aug 03, 2021 5:39 pm
Have you emailed us about this?
Posted: Tue Aug 03, 2021 5:47 pm
by jdmalex313
Not yet I called RT tuning about this & they told me to go to forums & here I am
Posted: Tue Aug 03, 2021 5:50 pm
by jdmalex313
Also said that I’ll have to fill out a form shipping my ECU To hondata but i can’t ship it myself have too do it through one of the dealers.
Posted: Wed Aug 04, 2021 9:56 am
The dealer should provide you with all forms and paperwork and instructions when you purchase from them.
Just getting Hondata will not resolve errors if there is an underlying issue that needs to be addressed.
Posted: Thu Aug 05, 2021 9:52 am
by jdmalex313
Kinda Stuck on this question
What kind of K-Pro are you ordering?
K-Pro for ‘02-‘04 RSX
K-Pro for D17 Civic
K-Pro for S2000 (2000 - 2005 only, must supply PRB A01-A12)
K-Pro for S2000 (2000 - 2005 only, with new PRB supplied by Hondata
K-Pro 05-06 RSX or 03-06 MT Element K-Pro with adapter harness. NOT for use with engine swaps. Base & Element should use PND and Type S should use PRB ECUs.
K-Pro Upgrade from Reflash - Please provide the name of Dealer reflash was purchased from. Reflash dealer name
Which one do I choose ? If my ECU Code Is PNF
Posted: Thu Aug 05, 2021 9:57 am
Posted: Thu Aug 05, 2021 10:23 am
by jdmalex313
Appreciate the help
I just finished with the forum do I send it too hondata ?
Posted: Thu Aug 05, 2021 10:27 am
Have you purchased this through the dealer?
Posted: Thu Aug 05, 2021 10:28 am
by jdmalex313
Yeah Pure Tuning Is Dealer I talked too
Posted: Thu Aug 05, 2021 10:36 am
The dealer should give you instructions and all the forms and invoices needed.
Posted: Thu Aug 05, 2021 11:35 am
by jdmalex313
Billing is set all I need is the info to send my ECU
Posted: Tue Aug 10, 2021 7:11 am
by jdmalex313
Just received an update that my ECU arrived to Hondata wanna have confirmation that you guys have it.
