how to get test outputs working
autox19
Post by autox19 »
because my B is in a fiat I have to do a bunch of custom wiring. I am working on the fan relay and was going to use the test outputs for this. I have the computer on and connected. I have the ignition on (heard the fuel pump prime) I clicked realtime update, then I went to test output and for a test (as it is loud) I clicked on the fuel pump. nothing,... what am I missing?
Odie
fiat x19 with honda b16
Re: how to get test outputs working
Do you have your calibration open?
autox19
Post by autox19 »
I downloaded the calibration. And have it open when I go to test.
Odie
autox19
Post by autox19 »
Here is a short video
https://youtu.be/eauCXcSvLNY
Odie
It sounds like there may be a wiring problem in the vehicle. You should try the ECU in a known working vehicle.
autox19
Post by autox19 »
The car runs great (at the moment, it is part fiat after all who knows how long it will last) not sure what would cause testing not to work yet everything else does.
Odie
autox19
Post by autox19 »
got it. not sure why.. so I also last my display (tunerview) so I went to see if the sensors were showing up in live view. nope. googled that and I had to turn off onboard datalogging. upload it, turn it back on and upload it. all is well. very strange. obla di obla da al is working now.
Odie
B16 in a fiat X19
