Check System
Posted: Fri Jul 30, 2021 5:20 am
by Bones126
Still have an issue with a "Check System" warning coming up on the dash.
I have disabled VSA & ELD. It appears to happen as soon as I move off.
Thank for any help.
Re: Check System
Posted: Fri Jul 30, 2021 6:19 am
by Bones126
Bones126 wrote: Fri Jul 30, 2021 5:20 am
Thank for any help.
There are no error/fault codes stored.
Re: Check System
Posted: Fri Jul 30, 2021 6:56 am
What vehicle? For most vehicles you cannot disable VSA without generating an error.
Re: Check System
Posted: Sat Jul 31, 2021 8:54 am
by Bones126
Hondata wrote: Fri Jul 30, 2021 6:56 am
Euro FN2 2007
It was happening before disabling the VSA.
Thanks.
Re: Check System
Posted: Mon Aug 02, 2021 8:59 am
If you datalog with both USB's connected, what errors are there?
Re: Check System
Posted: Mon Aug 02, 2021 1:02 pm
by Bones126
Thanks, I’ll give it a go.
Re: Check System
Posted: Tue Nov 16, 2021 6:36 am
by Bones126
Spunkster wrote: Mon Aug 02, 2021 8:59 am
Hi Still getting the system error come up about 5-10 seconds after starting the car and being stationary. I can't find any fault codes.
I have also fitted a new battery, so know that's not the issue.
You say both USB connections, I take it you mean connected to the Flashpro and then the traction control unit? If so, I have checked for errors doing that.
To confirm, the issue only started once fitting the traction control unit.
thanks
Dave
Re: Check System
Posted: Tue Nov 16, 2021 10:02 am
Please post your calibration and datalogs made with both USB's connected showing when this happens.
