Got tuned with MAP Port unplugged, do I need to re-tune?
byk24mr2
Post by byk24mr2 »
I got my K24 swap (MR2 Spyder) tuned, then realized I should have plugged the MAP Port on the throttle body. Do I need to re-tune since I had a vacuum leak when tuning, or will the maps compensate once plugged?
Re: Got tuned with MAP Port unplugged, do I need to re-tune?
You will probably need to discuss this with the tuner so they can check it and see if additional tuning is required.
