S300v2 = 34,000rpm and 206th gear?
Posted: Sat Jul 10, 2021 4:21 pm
by Raf99
All was fine with this P28 / S300v2 for years now. This morning the car was running, working fine. I moved the slider bar in S300, the car died.
Upon trying to start I have a electronic boost solenoid going crazy and SManager showing me this with ACC on. Can't upload, and no parameters available. Is this hardware or software?
https://www.youtube.com/watch?v=rU8RNjbbIwQ
Re: S300v2 = 34,000rpm and 206th gear?
Posted: Sun Jul 11, 2021 3:00 am
by Raf99
More info:
- serial number of the s300 inside the ECU
-- 25793? Red PCB / S300 V2 (not sure where to find the S/N on this)
- version of software being used (Help, About)
-- 2.7.6.0
-- can't load it
-- N/A
- what sort of vehicle you have
-- 1993 honda accord w/ H22A
- what sort of ECU you are using
-- P28 ECU w/ S300 V2 ECU with PWM boost control
Posted: Sun Jul 11, 2021 3:20 am
by Raf99
Did find this post which is close to mine.... , seems the best bet is to try another ECU (which is impossible without purchasing one).
viewtopic.php?t=9863
Posted: Sun Jul 11, 2021 4:13 am
by Raf99
I also found it weird that as soon as I move the slider bar for IACV in SManager the car responds immediately without using the upload button. Live feed option?
Posted: Sun Jul 11, 2021 3:30 pm
by Raf99
After re-seating the S300 module etc, this is what I get...... so hopefully it's just the S300 portion and not the ECU. Not sure.
Posted: Mon Jul 12, 2021 9:47 am
Do you have your calibration saved on the laptop?
Posted: Mon Jul 12, 2021 2:13 pm
by Raf99
Yep. Tried new calibration and clean installs.
Posted: Mon Jul 12, 2021 3:02 pm
Is J12 cut on the ECU?
Posted: Mon Jul 12, 2021 3:42 pm
by Raf99
J12 is cut on the ECU. and submitted.
