New to Hondata
Posted: Thu Jul 08, 2021 2:13 pm
by Minamoto
Trying to make sure everything is ok for the 93 Base map Tune. Seems like something is holding my boost back a bit. Didn't know if anyone is able to help me. Any Help is appreciated.
Uploading my first datalog of driving to a spot and doing a 1-3 gear pull. Tried to keep it nice and short.
Re: New to Hondata
Posted: Thu Jul 08, 2021 6:19 pm
Boost is low. Intake temperatures are very high, which is probably the reason.
BTW don't drive into the rev limiter. It is not good for the engine.
Re: New to Hondata
Posted: Thu Jul 08, 2021 7:29 pm
by Minamoto
It was like 90 degrees out. I'll have to go out at night to try log.
Re: New to Hondata
Posted: Thu Jul 08, 2021 7:53 pm
by Minamoto
70 degrees outside definitely helped, saw 24 psi on the gauge. Posted 2 more logs, I don't usually go to the limiter, just did it for the one log.
Re: New to Hondata
Posted: Fri Jul 09, 2021 8:12 am
I think the AFM could use some tweaking - a the higher flow it is under reading by about 4-5%, and it is best to get negative fuel trims.
Re: New to Hondata
Posted: Fri Jul 09, 2021 8:39 am
by Minamoto
What would cause that? I'm not confident to tune it myself outside of the base maps. Would moving down to a 91 base map help that? Been told our 93 is kinda iffy around here sometimes.
Edit* I don't believe the gas I got has ethanol in it but I did check the ethanol free gas. Also not sure if this would change it. Also appreciate you taking your time to help me out.
Re: New to Hondata
Posted: Fri Jul 09, 2021 10:33 am
Selecting E10 fuel will give you a 4% fuel trim that would be about right.
Re: New to Hondata
Posted: Fri Jul 09, 2021 11:17 am
by Minamoto
I will try this asap when I'm off work, really appreciate the help. Ill try to get a log when it cools down again.
