Create Boost Tables Question
Posted: Wed Jul 07, 2021 1:41 pm
by G. Wiffington
Good afternoon all,
For creat boost tables, if you set it how you want & then go to your map..if you select to only show N/A tables only (to make adjustments) does the creat boost tables forget/erase the setting changes you made in regards to retarding timing per PSI?
Re: Create Boost Tables Question
Posted: Wed Jul 07, 2021 3:32 pm
It does not change the tables, it just hides them from view.
Posted: Thu Jul 08, 2021 5:22 am
by G. Wiffington
Thank you for that confirmation!
