Unable to view/edit ignition,vtec etc. Fk2?
B_devz
Post by B_devz »
Hi im new to Hondata and needing some help.Im stumped and need some advise from any of the admins or forum users.
Im trying to tune my honda fk2 and when going through new calibration i cant seem to view or edit any of the parameters from any of the menus, ignition, vtec, fuel etc. 🥺
Is it because the fk2 is not fully supported by hondata?
I hope this aint the case as i just spent £600 on the flashpro.
Re: Unable to view/edit ignition,vtec etc. Fk2?
FK2 is supported by us. Are you loading a calibration? Are you opening the parameters and table window? Perhaps a screen shot will help.
B_devz
Post by B_devz »
Hi , yes i select new calibration ,my car/model from the list and then select one of the available base maps.
After that i cant seem to select anything such as intakes fitted, headers, exhaust etc. It loads the base map and i see the calibration menus from the left but i cant select or open any other than, turbo , rev limiter and maybe one other.
Funny thing i noticed though was on registering the flashpro to my details i dont have the option to instant jailbreak it as its already showing its jailbroken 😦 i havent had a code for my vin generated to jailbreak it.
I know this cant be right as fk2 and fk8 have to have the ecu posted off or instant jail breaked.
I will try get some screenshots asap
B_devz
Post by B_devz »
Screenshots, hope these help.
The calibration window is showing and looks normal. Are you opening the tables window? What do you expect to see?
As for the jailbreak, are you the first owner of the vehicle? Are you sure it has not been jailbroken already?
B_devz
Post by B_devz »
No I cant confirm if the vehicle was jailbroken before as im not its first owner.
When i click on any of the sub menus from the left to open up tables, take ignition for example it shows or opens nothing only blank, it does this for everything except the boost drop down as you can see from the screenshot.
I tried returning ecu to stock , unplugging and try again new calibration but its the same eachtime. 😧
It sounds like it was previously jailbroken.
If you go to the throttle section and click on the Torque 1st (comfort), does a table appear?
B_devz
Post by B_devz »
Let me get back to you on the torque menus tomorrow as its late at night here, il send some more screenshots . Thanks for your help so far.
B_devz
Post by B_devz »
hi again guys, Im pleased to say i can now get the tables open and can view/edit the parameters.
not exactly sure what fixed it as i left the flashpro plugged into the car and laptop for a few minutes and tables started to just show eventually.
thanks for your replys and anyways.
