KManager - Injector Size vs Flow Rate (FIC 2150)
Posted: Thu Jun 24, 2021 12:27 pm
Stupid questions:
1. Am I supposed to simply put the actual injector size into "Injector Size" in KManager, or am I supposed to use the "Flow Rate" (provided by Fuel Injectors Clinic) based on my base fuel pressure. For example, with a bfp of 58.0 PSI, the document that came with my 2150cc injectors states the flow at this pressure is 2619cc.
2. Does having a return style fuel system change the injector size or voltage offset/dead times entered into KManager?
Long story short, I tried starting my K24 and I suspect it's getting way too much fuel. Right now I'm using 2150 for the injector size in KManager.
Thanks!
Joe
Thanks!
Joe
