Wiring AEM Pressure Gauges - Analog Inputs
Posted: Wed Jun 23, 2021 6:32 am
I am prepping to wire AEM pressure gauges into the s300 for datalogging purposes. I'm using AEM 30-4401 Fluid Pressure gauges, 0-100psi, for Oil and Fuel Pressure. I have included the AEM connection diagram and the s300 Analog Pressure Diagram.
I have a switched fuse block, which the gauge is wired to, for both the power and ground. I plan to use weather-pack connector, and wire the 0-5v white output from the gauges to the analog 0 and analog 1 inputs. I do not see any reason to utilize the analog ground, am I incorrect in this? Again, the fuse block is switch power & the chassis ground for the gauges already.
