VSS Output Kpro v4 02 rsx type s
Posted: Tue Jun 22, 2021 4:22 pm
I have a 2002 rsx Type s k20a2 engine 6 speed transmission both original to the car. I Have installed a70mm throttle body and a skunk2 injen cold air intake and skunk2 intake manifold. Injectors have been increased to 410 cc.
After installing the Kpro V4 all is well except a P0500 error code. After researching, this forum as others, it led me to the fact that the ecm has no input from the VSS. The rub is that I cant find the fix. I have double checked that the sensor is set to low frequency and that the proper transmission has been selected. The only fix so far is selecting the constant speed choice but that choice seems to render VTEC useless.
By the amount of posts seen it is definitely a pattern failure and I know one of you gurus have figured this out.
Thanks in Advance
Thanks in Advance
