FK8 2020 EU - disable start/ stop
Posted: Sat Jun 19, 2021 10:52 pm
by mariusramm
Hi guys,
It seems that the 'disable start/stop' function is not working after my reflash.
Car: Civic Type R FK8 2020 European market
engine code: 5BF-E34
And also: is there a way to disable that stupid and useless fake engine sound from my speakers? Is this something that can be done from FlashPro or the only way is to remove that device from the dashboard?
Thank you
Re: FK8 2020 EU - disable start/ stop
Posted: Sun Jun 20, 2021 6:24 am
The operation of the button in the vehicle, or the stop/start operation, or the disable option in FlashProManager? And please elaborate on 'not working' and also provide the exact calibration.
Engine sound is nothing to do with the ECU - module under the dash. viewtopic.php?t=23425
Posted: Sun Jun 20, 2021 11:02 am
by mariusramm
Thank you for your reply, I'm sorry for not being clear enough, noob here.
I will better describe on a step by step basis:
1. I've used as a base, map called: Civic Type R FK8 US 2017+, 93 octane
2. In the "Misc" option, "auto stop/start enabled" is un-check, as seen in the attached pic
3. I've uploaded the map into the ECU.
4. When I start the car, I still have to push the "auto start/ stop" button that is located near the shifter to stop the "auto start/ stop" function. The car does not start with this function already disabled.
Posted: Sun Jun 20, 2021 5:21 pm
#4 - does the engine not start or is it just that the auto stop function is not disabled?
Does it do this when using the 'factory settings'?
Posted: Sun Jun 20, 2021 10:01 pm
by mariusramm
4. The engine starts, there is nothing wrong with the car. It's just the auto stop function is not disabled according with the map setting.
In "factory setting", the car starts with this function "on". I have to press the button near the shifter to disable this function that keeps stopping my engine when speed is 0.
Posted: Mon Jun 21, 2021 3:03 pm
by Tierlord
I think what he is referring to, is the symbol in the dashboard, which indicates that start/stop is turned off.
On an OEM car, you have to push the Start/Stop button once, to turn it off and get the said symbol.
If you disable start/stop via Hondata, you don't get the symbol. Which is a good thing in my opinion. Since the engine really does NOT shut down when you stop, even without you having to constantly by bothered by that symbol in your display.
Posted: Mon Jun 21, 2021 9:22 pm
by mariusramm
My bad, I thought that the system is disabled only when that symbol is displayed. I will go for a ride later and check.
Posted: Tue Jun 22, 2021 9:13 am
Thanks for the clarification. I'm interested in the answer because I never got much feedback after adding in the auto stop disable option.
Posted: Tue Jun 22, 2021 10:06 am
by mariusramm
Sorry for the delay, I had no time today for a run and a feedback.
Posted: Tue Jun 22, 2021 2:16 pm
by Tierlord
@hond
Hondata wrote: Tue Jun 22, 2021 9:13 am Thanks for the clarification. I'm interested in the answer because I never got much feedback after adding in the auto stop disable option.
If you need feedback.. Disable Start/Stop works for sure, but as far as I can tell, you can never turn it back on again (totally disregarding the symbol in the dash - I'm only talking about the actual engine shutdown).
Posted: Wed Jun 23, 2021 5:49 am
by mariusramm
Update: this is correct. Disable start/ stop works with the same mention as above. It does not matter if you press the button and that symbol is "on" or "off" on the display.
Sorry for not checking, I was only relying on that symbol.
Thank you Hondata.
Posted: Wed Jun 23, 2021 5:56 am
Thank you all.
Posted: Sun Oct 08, 2023 2:26 pm
by thesilverbullet
Is this feature available for US market - '23 RDX SH-AWD? I do not see it listed as an option for US market. I see it listed for Euro version of FK8...
