Low RPM/Partial throttle knock detection (new issue)
dglidden
Post by dglidden »
Hey all
My car sat for a month after my last HPDE event. I went to drive it yesterday and am now getting about +17 knock detects at low rpm when I give it partial throttle. At the last HPDE I had to change my knock sensor because the connector broke off the sensor. I used an ACDelco from a local autozone. The car ran fine the rest of the weekend and drive home. I'm attaching a short data log showing the symptom as well as my configuration. Any help/suggestions would be appreciated.
Re: Low RPM/Partial throttle knock detection (new issue)
Can you hear audible knock?
dglidden
Post by dglidden »
Negative. I dont hear any audible knock. Additionally this is only at low RPM if I give more throttle and hold it knock count does not increase. Its only when starting to give it throttle.
-Donovan
Have you tried reducing the timing in the areas it is knocking?
dglidden
Post by dglidden »
No, I wasnt sure if thats the proper next step or not. This is the same tune I've run for awhile so it'd be weird to have to change the timing no?
I have an appointment with my tuner to take it to him on Tuesday
-Donovan
Then I would wait to see what the tuner has to say.
