Reading Spark Plugs
Reading Spark Plugs
I've been tuning my d16z6 and I've noticed that the heat discoloration on the group strap looks awfully hot. I've been using DET cans and I haven't heard any pre-ignition or detonation. I'm running pump e85 (could be as low as e51), a gt3582r at 25psi, and my air intake temps are always around 105-115 F in full boost. My compression ratio is 8.8:1 Could someone look at my ignition map and see if something is wrong in my timing. I run 11.5 AFRs WOT.
