06 civic si coupe need help getting it running right
tripy4life
2006 Civic Si got on trade this is what was on car and tuned for but now it doesnt have a turbo but just about every thing is same no turbo i need help getting it to run right!!!!!
Performance
Greddy RS Catback
CxRacing Sidewinder Turbo Manifold
CxRacing 4” exhaust
CxRacing Front Mount Intercoller
CxRacng GT35 stage 2 Turbo w/ 8psi waste gate
CxRacing BOV
CxRacing Open Dump Waste Gate Tube
CxRacing 4" SRI
DW 1000cc Fuel Injectors
DW Fuel Pump
Hondata Flash Pro Tuner
Honda 4 BAR Map
Hallman Boost Controller
Clutch Master FX400
Performance
Greddy RS Catback
CxRacing 4” exhaust
CxRacing BOV
CxRacing 4" SRI
DW Fuel Pump
Honda 4 BAR Map
Clutch Master FX400
Re: 06 civic si coupe need help getting it running right
So now that the turbo is removed, what do you have for an air intake pipe? The CX one wouldn't work without the turbo which is why I ask. Also, what do you have for a header or exhaust manifold, as that too wouldn't work without the turbo.
Does it still have the DW1000cc injectors?
Still has the Hondata 4 bar map sensor?
tripy4life
it has a cheap cold air intake for now yes with the map sensor and stock exhuast manifold
tripy4life
yes still has the dw 1000
Are you driving the car right now with the tune for the turbo setup? If so, do you have any datalogs?
Does it run terrible, I noticed your message was asking to help make it run right.
tripy4life
run bad on turbo tune so i am using a preloaded calibration its is better but rich ill get a datalog within next couple hours. stuters when vtech kicks in so will be a simple basic datalog
tripy4life
here is calibration on now
If it's weird in vtec, then don't do any vtec runs yeah, just get some regular driving for now and we can go from there.
tripy4life
ok heres a datalog i just did
The datalog you posted isn't from today, the date says 5.31.21. And it's showing the engine making 8.6 psi of boost, so it can't be the right datalog if you have removed the turbo. The calibration file you posted isn't being utilized by this datalog either. Double check the datalogs in the FlashPro itself.
tripy4life
that was weird this should be it
Yeah that looks better, so you're sure the calibration in the car is the one you posted? The first problem I see is the cam angle is not following the cam commanded angle whatsoever. The ignition being delivered to the engine does not follow the tables either. This leads me to believe the calibration you posted has not been uploaded to the ECU. Can you double check that, do you know how to check the last calibration uploaded through the FlashPro?
tripy4life
Connect the Flashpro to your laptop. Open FP Manager, at the top there is a tab that says "FlashPro", click that and a box will open. Then click the "calibrations" tab and it will say which file was last uploaded.
tripy4life
yeah i checked that its the one i uploaded this file is the one i tried first so car might still have this one
